6n2 mods?
hey all I'm pritty new hear
just got myself a 6ns gti
just woundering what are the most easyest cheep most common? mods to do?
will post pics up of the polo when i have cleaned it
thanks
justin
  • Replies 12
  • Views 14.5k
general things like CDA air filter, straight through exhaust system, debadging the rear etc etc.
the best thing to do is look through the gallery section and get some ideas from there, the more original you are the better :)
welcome to the forum.
Jon
First mods on any car are normally lowered suspension, Exhaust and Air filter.
As said above... look in the mk5 gallery for some cool ideas.
If you can afford it, coilovers are the first thing to do. Best value for money IMHO! I wish I had fitted mine sooner than I did 8-)
For simple cheap mods, try aero front and rear wipers, black or differently-coloured "VW" badges, BMC air filter, Audi TT alloy pedals to replace the original rubber ones, or spraying your interior rear-view mirror satin black.
Si
I need some aero wipers!!! Where's the easiest place to get them? Anywhere i could order online?
Did later spec 6n2's have aero's? Could I get genuine vw ones?
IMHO 6n2's only need to be lowered to look good! You can do more but coilies are the best mod!!!!
I got my aero wipers from VAGParts originally. Sadly, they've since ceased trading :(
I've got a rear Passat estate aero wiper, and on the front I have two passenger-side Lupo GTi aero arms and blades. They need a lot of work to get them to fit properly and aren't quite perfect even when you get them "right", but they do the job and look really good (IMHO!), sitting lower than the original arms and blades when in the rest position so that you can hardly see them when in the driver's seat. Cons are, you can't lift them up fully as they catch the bonnet, and if you don't get the alignment quite right the driver's blade clips the A-pillar!
You can of course buy the retro-fit aero blades these days, and just fit those to your standard wiper arms. Cheaper and a lot less hassle but they don't look quite as good!
EDIT: forgot to add, that all 6N2 GTis rolled off the production line with standard (non-aero) wipers front and back.
Edited by Si_GTi
Sod it i'm just going to get the retro fit ones!
I don't have a rear wiper!
Thanks for the info!
Cheap mods
Depends what cheap is though, cheap to some is 5 quid, to others it's 50?
Retrim the interior A B C panels and headlining
Debadge the rear
De-wiper the rear
Spray interior bits
Wolfsburg door pins
Front aero wipers
i carnt post in the mk5 section so hear are some pics
this is pritty much how it was when i bought it
then gave it a clay bar and polisg and wax and lowered it more,red trim round the grill also
then befor it went for trackin and camber i lowered it more,i carnt go any lower was my tyres are to big but I'm in the process of gettin a smaller profile tyre and new wheels
pics are off my phone so there rubbish
thanks for lookin
niiiiice man :)
Are they Toyo R888's??? Or Yoko Advans???
Are you running std 1.6 16v???
What are they like in the wet??? Much tread left??? If there is i'll buy em off you as i need more grip!!!!
yea they are 888's
and yep its a standard 1.6 16v
i haven't had chance to try them in the rain yet as its been nice since iv had the car,dont think there is a awful lot of tread left on them tbh
