6n gearboxes
hgi jus wondering I've been told that a g40 gearbox fits 1.4 16v jus wondering if any can comfirm that and whats the best g40 box code to go for for all roung good speed cheers
  • Views 1.3k
Best one for fitting into a 6n would be a CEK code.
If you deffo want one, then snap this up pronto.
http://www.clubpolo.co.uk/forum/index.php?showtopic=160984
G40 boxes are hard to geld hold of in any format, CEK code ones are hens teeth TBH.
thanks for reply isit a straight replace ment or is there anythingg else need to fit this what are these boxes like ratios/strength cheers
They are no stronger than any other 085 boxes, but without the ghey 6n/6n2 output flange setup they should last longer. Never seen an older gearbox fitted to a newer polo. You might have to get drilled and tapped some holes for the 6n gear linkages????
they must be stronger because sum people are pushing 170bhp with no problems..
Some people are pushing 200bhp out of them with little problem. They are no stronger.
As said , its the proper ghey 6n design of these which causes the weakness.
Here is a picture from Majic79's thread showing the FAIL and 6n flange set up. None of those bits occur in the older polo gearboxes.
Taper rings fail > diff bearings fail > main shaft bearings fail > gearbox fails
