Wing mirror.
Does anyone know how to fit them back on a 6N, or am going to have to buy a hanyes manual earlier than i thought?
It stayed on due to the cable inside but bashed the cr*p out of my door. Can't tell how bad it is yet as it was dark when it happened.
I will be very greatfull for any help, need to get it sorted before wednesday as i am going back to college, can't turn up to college with a taped on mirror. :lol:
  • Views 858
There'll be a piece of plastic on the inside of the door over where the mirror is/used to be attached. Pop this off and you should see where the bolts are.
Thank you. thought it might be like the golf were you have to take half the door off. cheers.
Dead simple job mate. I put another on mine this afternoon after some arse snapped it off. 10 minute job max!
One thing though you might need to pop part of the door card away from the door to get at the bottom screws.
Yeh i did have to, but it was ok though cause i found the screws that fell off. :-D Just got to sort out the mess it did to my door now.
