Newly acquired mk3 cl coupe, what do I do?
I'm appealing to all of you who have done any kind of upgrades to your polo mk3. I have just got my hands on a beautiful cl coupe 1.3. It's a White 1994 L reg, a couple of small "car park" dings here and there, fsh and done only 30k miles!!! I absolutely love it! It's in almost pristine condition. The few little snags are; couple of the little dings I. The drivers door have started to rust, so will involve rubbing back, treating and repainting. The same in the boot, although the is a bit more of a dent there too. The drivers door card seems to have gotten damp at some point and the vent on the door shows small signs of rust, this would indicate either a leak of sorts or that the door is holding water. The heater control will only let me selet speed 3. The rear silencer has developed a hole, clearly an MOT failure, but it makes it sound like a real muscle car :-p and I've got 11 months ticket left anyways :-p and she seems to top right out at about 87mph on a flat motorway.
Ok, so firstly, have any of you got any ideas about any of the above? Common faults etc? Some of it's fairly obvious, I know, ie the silencer, well that leads me on to my next point.
I want to make this car my little project. I'm not currently in a great financial situation so anything that requires little or no spend but enhances the cars performance or appearance is where I need to start. However over time I'll be looking to put some funds into performance and styling. I want to keep the car looking fairly standard on the outside, considering things like the GT bodykit, a tasteful set of alloys, possibly debadging it and a nice interior, you get the idea.
But mostly I want to increase the performance. So when it comes to replacing that silencer, either because the MOT's due or because the police have told me to, I would like to look at upgrading the whole system. It's a single carb, could I look at double? Who knows...
Anyways, I think you get where I'm going. I'm obviously new to this forum, so any help you fellow enthusiasts could give would be greatly appreciated.
Forgive my ramblings :-p
and thanks in advance
  • Views 579
Hello and welcome.
You mentioned single carb? The 1.3 CL is an SPI, so no carb there.
Performance enhancing for the 1.3 engine is such a common question, luckily, it's easy to do something like a GT conversion or add GT parts such as camshaft.
A performance exhaust system and manifolds will let the engine breathe better and an ECU chip will also free it up a bit (Poloace supplies these chips and has his own section on here).
In terms of aesthetics, there's loads of wheels around which will look good, depends what kind of look you're going for I suppose.
Hope this helps.
