HELP ASAP. 6n2 coil fitting question.
fitted my coils but there creaking like hell. looks like the top of the springs are catching on the metal plate at the top of the coil unit.
which springs did people use the ones the same diameter as the helper or the larger one that tapers down?
and do you use any of the original suspension? such as the bearing that lets it rotate? thanks
  • Views 753
anyone have a guide to fitting?
Haynes manual is your friend!
