Rear VW badge..
I'm thinking of spraying my rear VW badge black - is it easy to do?
  • Views 1.7k
I imagine on a 6n2, take it off, spray it black, put it back on :) There is a guide about painting plastic I'm sure somewhere .....
very easy, probaly need to take the front grill off to acces the front badge, the rear one just prys off.
Aye, easy. Although i'd advise splitting the plastic actual VW sign away from its rubber backing. And just spray the plastic badge as the rubber is black anyway.
I initially didnt bother and the paint cracked on the rubber within days.
Just split and and glue it all back together, or not use the backing at all. That looks pimp imo.
Yes mate its easy, on the 6n2 I'm guessing there also adisive so get a hair dryer or heat gun and warm it up, use a credit card or somthink that wont scratch paint to get the badge off.
it shouln't need alot of sanding maby just use some 1200grit and go over it lightly.
Use plastic primer
spray and wait to dry, then sand smooth with 1200 again.
then spray matt black or gloss black.
if you spray matt black, dont use laqure.
with gloss black you will want to laqure it to to give it a shine
you wont need much paint, just a can of primer, matt black or gloss black and laqure if you are spraying gloss.
