why BMC?
I've noticed most polo owners that have a induction kit use BMC, i've never seen them on any other car.
Anyone know why this is? Is it a polo thing?
  • Replies 17
  • Views 2.4k
i would guess its because the air intake is on the top of the engine and if you had a normal cone filter it would end up sucking in warm air, i think the bmc kits have a cold air feed which would be more effective giveing you a few extra hp . just a guess tho
Almost all throttle bodies are located on top of engines or nearer towards the back.
The BMC CDA is just popular because it has a carbon box which effectively keeps out the warm air coming from the engine and keeps the cold air inside the box at a lower temperature which helps with power gains.
I've never had one of these and to be quite honest, I don't think I'd pay £200 for something which is gonna give me no more than an extra 15bhp MAX. Save yourself £200 and get something else or get the BMC style ones which go about. Someone sells them in the traders classified I believe but there inbox is always full.
I opted for the Pipercross Viper kit in my Lupo GTI instead of the BMC. Slightly louder than the BMC and still works the same way. Haven't heard any bad things about either of the 2 kits :thumbsup: alot of people will say go for the BMC purely because majority of people have got it and is the best common one to get. Although i read up on the Pipercross and works fine like the BMC.
Edited by DJ_Troopa
Surely 15bhp is a bit optimistic also, maybe get 15bhp on a 400bhp car. I would be surprsed if an induction kit got you more than 2-3bhp, but then again I've never bought one.
Id expect more from 6 PC fans mate, 15bhp, no sorry more like 1/3 maybe not even that.
An Iduction kit won't give you 15bhp on any polo with a std ish engine.
But as above the BMC is popular as it's an enclosed induction kit... but there are other good options. The enclosed kits are better for performance where as the open cones will give more noise.
I usually tend to stick with panel filters in a std air box. But as that's not an option on mine i will be going for a BMC CDA eventually as atm it's got an open cone kit. Not at the top of my priority though as i don't seem to get much heat soak and if i did i wouldn't notice it that much as it just feels rapid!!
You won't notice much if any difference changing to an enclosed unit as the turbo will be heating the air up anyways.
Turbo cars are probably the worst effected by heat soak! The colder the air going in the better.
The colder the air going into the inlet manifold yea, hence why intercoolers are used. I imagine the turbo would heat up the air far more than the heatsoaked air going into it (I say imagine cos I don't know the ambient air temperatures that would be in the engine bay.) But yea the colder the air the better going into the turbo will be, but I doubt it would make much noticeable difference compared to cooling the airflow after the turbo.
the bmc in not recomened by some people on turbo cars and my bmc makes a diffrence compared to a std after market filter.
matt
I know what you're saying but trust me on this as i've done it! An open cone filter on my Ibiza Cupra made a big difference to the power compared to the std airbox with a panel filter. I put it on just to see how much difference it made to the noise of spool up and dv noise... the results were good but it seriously felt a lot more sluggish.
LoL maybe +15 was a bit over the top but more of my other points proven.
Anyone also know if "Sentral" from the Traders Classified still lurks about on this forum.
His message inbox seems to have been full for well over a month now. :S
Edited by jooshy63
its a SCENE thing tbh
You'd not catch me spending £150 on an air filter!
Get a nice 4 branch for that price.
You can get BMC copies for £40, look pretty much identical just don't have the sticker, or the rest of the fitting kit which can be go cheap anyways.
fella on here sells the lookielikes sentral i think his user name is, they anygood?
