pressed plates
what has everyone used to stick there pressed plates on with ?
  • Replies 15
  • Views 1.5k
Omg josh
Sticky Pads
Omg josh
Sticky Pads
i want something stronger lol
A mate of mine once used an Araldite resin
It was fine until a copper told him to take the plates of cause they were illegal :lol:
Omg josh
Sticky Pads
Why i used them on the white 1 and the blue 1 has them as well and never had any prob.
i just have a lot doubled sided foam padding on my back on and 2 cable ties on the front haha.
I used Velcro ;)
Sticky pads from Halfrauds :thumbsup:
Martin.
Martin.
are shit and expensive :thumbsdown: they dont hold the corners of my pressed plates (as the front bumper's plate recess on the 6n is curved) I need something stronger to bend the plate flush, if that makes any sense?
I haven't put mine on yet but I'm going for the sticky pad approach too..
The plate is aluminium,which is malleable,and the ideal course of action seems to be to bend it slightly in order to match the profile of the bumper recess - vastly reducing the stress on the padded sticky tape (you can buy it in rolls from hobby/craftwork stores cheaply if you think Halfords are taking the piss).
dont stick mine on. use plate holders instead. Easy to change from pressed to plastic and wont fall off.
Got a spare set i dont need if anyones interested?
heavy duty velcro !
you dont wanna stick them on too well....
cos your only gonna have to take them back of when you get pulled for it.
sticky backed industrial strength velcro is by far the best
bend the plate slightly to fit the curve of the recess then pop a 2 inch square section at each end of the plate, thats all you need, the industrial stuff is seriously strong!
also means you can remove the plate easily, swap it for show plates and clean behind them when you wash the car
seemples
Plate surrounds. Gonna go for the velcro route once i can get someone to steal a little bit of it for me though :D
