Poppy out rear windows for mk4
Hi all
has anyone tried pop put windows like the happich windows for a mk2 golf????
  • Replies 15
  • Views 2.3k
i was thinking about the exact same thing today talking to some lads i go to college with haha.
Was thinking of using wing mirror motors to make them electric?? But it's sourcing seals for them me thinks would be the biggest problem the hinges maybe use ones from a pug 205 but have the glass for the polo modded to suit???
i was thinking about trying to get the hinges and whatever else is needed off a Saxo and just having them manually operated.
but I'm unsure whether the glass needs drilling to mount them or whether they just bond on.
Hinges etc can be found on Lupos with pop out windows.
i started a thread about this a while back think someone said that i would have to drill the rear windows to make the wholes for the hinges
I'm sure you could get a window company to do that cant you?
[and I'm not on about Safe Style UK haha]
Your probably can rob, i think the windows will have to be drilled to get them on.
Maybe try a tinting place, they may have had to do it before :?
I'm sure any local glass place could drill them quite easily and doubt it would be too expensive either.
black and decker ftw :lol:
What And a dust pan and brush for after wards lol
Saxo ones bolt through holes in the glass, as for drilling glass its very easy but even easier to mess up.
I've used pillar drills in the past for glass and set it to the slowest gearing with a proper glass bit and oil to keep the bit from jamming and shattering the glass.
Personally I would use lupo ones tbh as they are a vag partand will look less out of place, also could the seals be cut and welded together like plastic welds? Could be the solution?
So one last thing, how would you secure the hinges and clasp to the car?
Hi,
new to the site but thought i'd shed some light on the matter,
From what i understand you cant drill toughened glass as the tinyest pin prick breaks the outter layer and explodes it,
If you could get a glass company to make you laminated ones 8-) then you could drill them ( or they could)..
Will
I'm pretty sure you can drill toughened glass,
But i do know it shatters easy enough!
i make pvcu windows and order the glass in, sometimes we get people wanting cat flaps in their glass in their double doors, therefore they 'cut a hole the unit, but it is definatly toughened to be underlined by the health and safety rules!
Sorry for the life story :)
