6n/6n2 front brace.
here i have for sale brand new never been used, front aluminium high polished strut brace.
cba with the fitting and I'm going in a different direction with it all so dont need it now i payed £40
LOOKING FOR £30 preferebly collected as its quite big, but willing to travel to the severn bridge (if in england).
i live in pontypridd just out side cardiff. PM if interested.
  • Replies 10
  • Views 264
how do you fit this exactly??
sorry for my ignorance but i truly dont know how to fit these
I think you drill holes onto the front turrets and bolt it on manually mate.
That's what I had to do with my rear one yesterday
so I'm assuming that there is no special bolts needed??? just a simple m8, or m10 or whatever size is needed from your local hardware store??
also quick question to anyone with a 6n2 front strut brace mounted, do i need to relocate anything??
Washer bottle could get in the way mate.
You will use standard nut and bolts, they are quite chunky bolts.
is the washer bottle easy enough to relocate?
the things you would need to relocate is your coolant expansion tank, not sure if there is anything else on the TDi model, but thats based on the 6n2 1.4 16v but there a similar setup, you dont need to touch your washer bottle
would you like to buy this then? i can meet you at sarn services if you like?
i am interested matey, but need to find out what needs relocating in order to see if the benefit =s are worth the hassle
just need to make a bracket or some sort to hold the coolant tank (the ball looking thing) away from the bar, its easier to have the bar and work around it as its hard to see what touches without the bar?
would you consider posting /? intrested in this
