6n2 bumpers
Would the 6N2 bumpers fit a 1995 polo 1.3 cl
  • Views 1k
Not without modification
Noo, would be to much work to do
Not really, not like you'd do it yourself.
Any good bodyshop will do it for you mate. Fronts easier than the back. If you get the back done you'll also need a smooth boot, unless you want two plate recesses.
it would be a bit costly i would have thought, as if you look at the top of each of the bumpers the are quite different.
So would be as if you used like the top bit of the 6n and modded it onto the 6n2 bumper
