89coupe boot problems
Dear all,
Got a bit of a problem, the boot on my 89 coupe will not open even with the key ant tips on how to open it manually
Cheers :shock:
  • Views 672
climb across back seat, remove panel from inside of bootlid and flick the lock from the inside by hand.
I had to do this with the smoothed bootlid on my GT.
Like jon said to open it. Chances are, you're got a broken pin in your boot lock cylinder (they're pretty prone to it). They're only held in with one screw from underneath so easy to take out and swap with one from a scrapper. Catch is, it probably won't have a key, but if you take the lock and your key to the main stealers, give them a couple of quid and ask very, very nicely, they'll be able to retumble to lock to match your key.
I had this myself with my old breaddie, I just took the lock out so I could press the lever from outside, and parked with the back of the car to a hedge, wall or lampost whereever I went til I got a new one, when I couldn't, I just tied the boot lid to the seatbelts with a bit of rope inside. :lol:
