bonnet lifters
Ok this is for anyone having trouble decyphering the german instructions supplied with the lifters,
Tools you need:
10mm socket or spanner
13mm socket or spanner
Some grease (copper or grease or something like that)
4mm drill bit
Tape measure
Drill
Instructions:
1. Open the bonnet and prop it as usual
2. Using the 13mm socket or spanner take the bolt closest to the windscreen off the bonnet hinge (both sides)
3. Put the think bolt and washer (from the bonnet lifter kit) in the bonnet hinge hole and tighten (both sides)
4. From the front of the car count the 3rd wing bolt and take it out (passenger side)
5. Put the thin bolt and washer in this hole (from the bonnet lifter kit)
6. Grease the ball pivots on top of the bolts
7. Attach a lifter to these bolts (thin end to the wing) (passenger side)
8. From the back of the drivers side bonnet hinge measure 40 mm towards fromt of car and mark it out
9. Drill a 4mm hole on the mark (between were the other wing bolts are)
10. Put the last remaining thin bolt and washer in this newly drilled hole
11. Grease the ball pivots on top of the bolts
12. Attach final lifter
13. Attach the fixing clips to the pivot cups on each end of both lifters
DONE!
please note this takes about 10 minutes to do once youve collected all tools
if you are a perfectionist you can take the original passenger side wing bolt saw the bolt so that you can take the painted washer off and use that under the lifter wing bolt and washer so you dont have an unslightly ring of primer around the pivot bolt!
Edited by Pepe
  • Replies 10
  • Views 1.5k
thanks mate
did it today on mine got the lifters from veedubmachine on ebay and there ace
updated!
Edited by Pepe
you legend what are the chances i was about to search for this exact same thing :lol:
Nice one! Glad to help! Get it done Frogger they look sick! U'll be seeing more of the polo now ross,got it back! Only downside is I had to give th golf back! Lol
Edited by Pepe
pics added
Stickey?
i take it your back on the road with the polo then, got any big plans on at the moment
Fitted these same ones today.. with help from your english instructions. Class mate! much appreciated!
What are bonnet lifters, and what do they do?
^^^ they lift the bonnet up lol by looking at the picture. how come you have taken the insulation thing off the underside of the bonnet.
