How to remove arches and sills?
Hey,
I need to remove the arches and sills from my mk3, can anyone give me some tips on how to do it without damaging them and just generally tell me how to do it?!
Thanks!! :)
  • Views 1.2k
The trims?
Drill the rivets with a 4mm (I think) drill. It's easier if you take the wheels off. You'll know it's the right size because you'll get laft with the rivet head stuck on your drill bit.
The trims?
Crikey that sounds like hard work! What about for the sills and the door bump strips?
Not really, half hour job at the most to do the whole lot. You could probably get the front ones by turning the wheels so you can get in, just depends how big a drill you're using.
Sills attach the same as the arches, so you'll need to drill rivets again. The sill trims tuck behind the arches so you'll need to bend them a bit to pull them out. Thing is you'll be left with thhe cut out in the arch trim where the sill trim goes through, which may look a bit strange.
Rub strips are stuck on, I think there's an FAQ on taking them off.
ahaha
The hard work comes when you've taken them off,only to find loads of rust/perforation and damaged paint underneath..
