Removing them horrible swirls.
Used the Megs 3 step polishers today using the megs sponge applicators.
After finishing it off and buffing the final stage off, I was disappointed to find the amount of swirl marks it left on the paintwork.
I've heard of G3 but I've read it's a cutting compound so I'm not entirely sure.
Any ideas or suggestions?
  • Views 709
I use G6 rapid witch is a cutting compound but only on freshly painted panels, i find using a supernatural machine stick is really good for leaving a smooth surface and doesnt show up swirls
G3 is too harsh to use by hand, brilliant stuff with a mop though. use plenty of water when mopping, if not, it'll burn the paint and you'll end up with even worse swirls.
