bonnet raisers?
HI All,
i want bonnet raiser on my mk4 polo but car find non any were any help please?
thanks
  • Replies 19
  • Views 4.6k
make one yourself,its easy enough:)
on google they jus show shite saxo's or punto we need mk4 bonnet raisers :D
Come on guys, can you not use the internet?
After 30 seconds I found them on ebay. Item: 350248210214
Is it raisers or lifters you lot are after...they are completely different things ffs.
Its raisers were after nt lifters were nt retarded lifters an raisers totally diff so its raisers to stop future confusion !
^ Then have a look at post #3 mate...
that google thing is genious.
I FOUND THAT!
I FOUND THAT!
Yes you did mate 77.gif...and what a find it was,i uset on every forum i'm on for
assholes that are too lazy or stupid to use google. :smirk:
Look easy enough to make? Allen head bolts and washers seem to be more common than what's shown below. Can be £30 for a set of polished blocks for a Ford, crazy Ford owners and their polished bits!
Edited by Tav
any body actually fitted these to a 6n ? cuz doe look hard too make so will have ago but just would need some pointers how to fit them would be appreciated (y)
I made my own out of an old roof rack took about an hour to make and fit. I put a block below the hinge raising the entie bonnet and hinge assembly, I just messured the length of the hinge, and the gap between the holes and drilled it out.
that the sort of thing you were looking to make?
i used solid plastic block [in the trade] on my rover turbo under the hinges and used longer bolts, and when bought my mk2 polo, already raised by removing the back bolt from hinge to bonnet on both sides, lifting bonnet and putting bolts back in bonnet only above hinge, making bonnet sit highier, not sure how safe this is so changed back now.
