Need some inspiration
Decissionssssss!!!!!!
I hate them!!!!!!!!!!!!!
Well box is in with sub, not for the layout of my build and i cant decide
one i thought about is to have the sub box at a angle in the spare wheels well going up and resting on the top of wheel well. and then flat mdf around the box, I'm scared that i wont like the box with the straight edges leading down and dont have the time or money to make some shape to it :(
Second idea is box on right side, amp on show, then if the amp is on show do i have it on a angle or just square to the box - Simple Build bus i cant decide whether i want the amp on show or not :@
Third idea - I dont have one give me some pictures and inspiraion :D
This is how it is at the moment : DSC00559.jpg
Post your thoughts and pictures - Photoshops welcome
  • Views 793
Anyone, doing the frame for my false floor tomorrow :)
man thats a sick install!! i want mine just like that man!! lol,
shame you live so far away, i make installs for a past time :( fibre glass it mate, make a frame to the size you want, get a bed sheet pull it across to how u want it, pin it on, then fibre glass it
Heres a few of how i did mine...
Did the floor in 2 pieces...still need to get to the spare wheel and
cut a small gap in i to get my hand in....
Carpeted the rear turrets and bought some black rear carpets for it.
Capreted the inside of the rear tailgate...
Mounted my Alpine V12 amp on a board that i made and attatched
it to the back seat...
Stuck the sub back in...
Hope that helps you a bit mate...
well box is payed for and was pre built so thats how thats going,
Bought the MDF today and also started making my false floor
Pitures in 10minutes
Cheers for those pictures by the way dude
Well heres what i have so far :)
the sruts will be hot glue-gun'd to the floor pan and then sealed with silicone ontop of these the frame will sit, this will be attcahed using basic screws and "L" shape brackets to protect the inside angle and to help the support, after this is attached the MDF will be cut to shape, and holes cut out for the box and amp, the MDF will then be carpeted and place over the box and all level with the boot lip (Plan anyway)
This is what i have done so far :)
Half frame, with struts on top of boot carpet to get a idea into my head
Frame on top of boot carpet
Full frame and struts
And MDF - I'm having to use two pieces as no where local had any :(
Ideas and ways on improving please @_
