mk2 polo bits
i broke up a mk2 polo 1.0ltr breadvan a while back but still have lots of bits left
1.0 radiater SOLD
fan shroud £7
full wireing loom inc fuse box,fuses and relays £15
front and rear wiper arms £2 each
door seals £4 each
interior door handles,winder handles etc from the doors £misc
window regulaters £10 each
front q-lights £5 each
ignition module and coil £15 for both
distributer with vacum SOLD
front seat belts £15 the pair
all engine mounts £10 each
starter £10
radiater fan £10
expansion bottle £6
ashtray and heater surround £8
clocks with 58k SOLD
clocks surround £5
heater controls from inside the dash £5
1 rear bulb holder £3
fuel tank (nearly new) £25
fuel tank sender unit floor cover £3
rear and front shocks covers(round plastic bits) £1 each
horn £2
horn push from middle of steering wheel £3
interior mirror SOLD
handbrake lever £7
4 speed gear linkeage £15
standard grille SOLD
exhaust manifold heat riser plate £5
water hoses SOLD
down pipe clamp £2
a bag of tiny trim bits,bolts,rubber bits,plastic bits ask and i will check if its there
Edited by low bay
  • Replies 44
  • Views 2.1k
Do you still have the dizzy by any chance? and if so what engine/year did it come off and can you put some pictures of a decent size up too please?
Tar J
could you post a pic of the gear linkage, want to check correct version. Thanks
do you still have the door seals? also do you have window seals for the doors?
vee dub 90,i still have door seals,think all the door window seals are here still
Hi bud do u have the rear reg plate lights ? cheers
Hey did It have an opening sunroof? If so do you have the two little 'arms' that hold the sunvisor that pops up when its opened?
Interested in metal door handle inserts if you have any and they're dent free
Have you got the steering column surround??? If so they in good condition??? Thanks
rk92 no sunroof sorry
dubpartz should have some will check
b/coupe yes got one £5 posted
hi mate have you got a fuel filler cap? to fit my 1985 breadvan?
the screw in cap or the wee door?,i have both
all still here!!!!!!!!!!!!
u still got the gear linkage for the 4spd pm me
hi there have you still got horn push from centre of wheel ifso pm me a price with postage please thanks steve
the heater fan switch from inside the panel as my brother turned it to far and broke the switch and now i have to fans
do u have the door window rubbers?
the bits that go along the bottom of the window, both bits on either side of the window?
stevie £5 posted
resident £4 posted
kat will have them all
cheers dude!
can i have both the drivers and passengers please, how much u want including postage?
also want a few more bits.
do you have the bonnet catch spring, the one on the bonnet next to the bonnet catch.
and the clip that holds the bonnet stay to the slam panel??
can't find mine...
Edited by KatPoloMK2
hello mate how much for the exhaust manifold shroud posted
Do you have the thin plastic cover that covers the heater matrix under the bonnet??
cheers simon.
colest £7 posted,is that the black onethat covers everything,it was broken
kat £2.50 a seal,i will check your other bits tommorow
money sent for horn push many thanks
cheers dude
kat i have all your bits off
