mk2 polo bits
Hi mate, do u still hav the fog light switch???
  • Replies 44
  • Views 2.1k
yes £6 posted
updated!!!!!!!!!!!
I'll take the wiper arms if you've still got them?
no probs they are still here
u still got the fuel tank and are you able to post it??
yes still here,would be about £15 to post
okayy what sort of payments do u takee??
Hello again
is the radiator expasion bottle a late one with sensor
cheers
melon
FUEL TANK NOW SOLD TO MEE :).
bits still left
hi do you still have the washer jets or just one of them
cheers
will have a pair on an old scrap bonnet
Do you have a right hand side parcel shelf support (drivers)...the rear parcel shelf clip is broken on mine.
Also any centre console and gaiter?
I need a bosch under car fuel pump for my 1991 mk3 1.0 coupe. Does the mk2 have the same pump or an engine mounted one? It should be on a carriage under the car with 2 fuel filters attached, a white plastic square thing and a normal metal fuel filter.
Is the coil, amp and wiring suitable for running bike carbs by any chance? So all i would need is the dizzy? Thanks very much
coil amp and dizzy are all sold
alright mate have you got the suspension topmount caps also icould do with the front suspension without the springs and shocks ie everything else
top cap mounts are away
have you got the inner door handle surrounds
