How to replace a 6n aerial base
Hi, I have searched but cant find a guide for replacing the aerial base on the 6n, I also need the part number for a new one from VW.
  • Views 771
Hi mate,
If its the actual receptor you need, its about £45 odd + VAT!! from VW. I need one as mines stopped working. To get to it you need to open the boot and remove the trim pieces from the rear of the roof lining, then slowly pull the lining down and you will see the bolts that hold the base of the aerial.
Neil
