mk2 polo help
i crashed my mk2 polo cupe s last year I've repaired all bodywork been jigged but the cambers out and castor replaced all suspension components still cant get rid of it tryed oavaling lower arm bolt hole and bringing the bottom of the wheel in it seems better but wen you drive it ot full chatt it fights itsself and bounces down the road almost and it puts strain on the driveshaft now theres now play in the gearbox drive flange and is now clicking and leaking gear oil slightly it also sits higher on the affected side than the good side so think it needs to be profesionaly mesured and jigged but not sure heared u can get subframe upgrades which allows u to ajust camber and castor not sure tho does anyone know were to get them from cheers
Here is one company that makes the subframe
http://www.clubpolo.co.uk/forum/index.php?showtopic=77066 The other being Polo Performance Services.
This allows you to change the caster but not camber. Camber adjustable TCA is whats required and/or adjustable top mounts which will allow you to mess with the camber. But really if you are going to be spending that much money just to get the car drive right you might as well look at another Mk2.
Have you taken the car to have a full alignment check?
yeah if your getting camber and caster issues with this you have some major alighnment problems... these arnt camber adjustable so any problems relating to that means somthings bent... are you sure the tracking isnt just stupidly far out? also a subframe wont realy help if the body is bent as it bolts up to the existing tca mounts... if they are off allready. the subframe wont be straight meaning your back to square one if not worse off as the sub relies on the tca mounts to keep the wheel centred in the wheel arch (i.e without arb)
