HEAT GUN METHOD
does this work? know its prob an old skool method.
any one done it? :-)
  • Replies 12
  • Views 1.4k
i've heard it does.. not tried it myself tho
it works ish but when the plastic goes grey again it goes twice as bad, ideal for selling a car
imo linseed oil is much better.
AutoGylm plastic conditioner is the best, better than that back to black.
Does you rubbers too, good to use after polishing to get rid of any white bits that you might of got on the rubber.
http://www.autoglym.co.uk/enGB/product-pro...il.asp?v06VQ=KF
after 11 years of bumper restorers/back to black etc etc even boot polish i have concluded linseed oil is the best - cheapest and easiest to apply
Heatgun does work.
But it doesn't get it perfect.
I've used peanut butter in the past and its worked and looked good for ages
Autoglym ftw, do mine once every 3 weeks, works awsum. My bumpers and arches were like a dried out dogs turd lol.
Used to agree that autoglym and autosmart etc were all good then i came across Carplan Black Trim Wax thru a mate ...WOW Black for weeks and weeks and looks mint ....Just DO NOT get it on your paint or you are foooooked! :)
Linseed.
I used the heat gun method on the front and rear bumper on my 89 polo about 3 months ago and on my mk2 golf GTI, they were at the time a very washed out grey and have been a nice black ever since, however its not as easy as pointing a heat gun at them and hoping for the best.
best type of gun is a dual temperature gun, start off somewhere not so noticeable on low heat , start with the gun about 5 cm away from the plastic you will see the bumper start to go from greay to black , the tricky bit is getting it hot enough to stay a nice black for ages without burning or melting the plastic.
Was a big learning curve for me but if you take the time and do it properley your confidence will build and the results will be spot on, if your not confident enough to try this then the best product I have found in the last 10 years ( and I have tried many ) is boild linseed oil, available from most DIY shops for about 2.99 for a liter.
Get some onto a clean rag and apply to the bumper generously (but don't slap it all over so it's building up and dripping) then buff of with another clean cloth so nearly all trace of the oil is gone , this will leave them looking as new for weeks on end.
Kind to the environment as there's no aerosol or chemicals involved and kind on your pocket too.. Both these tips/methods were passed to me by a very nice old chap in our local body shop who's been painting and restoring cars from way back when I was just a twinkle in my daddies eye.
hope this helps.
be warned though. linseed oil impregnated rags can spontaniously catch fire, so be very carefull how you store them
I just used some on my polo which had very grey faded bumpers, but now they look like new! :-D
