NOOB Coupe S question
What year was the coupe S released? I'm going to look at one its on an A plate? :?
  • Replies 21
  • Views 1.8k
From the beginning of the mk2 so Y reg iirc.
Just look at the V5.
Edited by kerrly
Actually not.
The Bready was released before the Coupe, but there's one or two very scarve Y reg's out I believe.
The Coupe was the sporty model, having sports striped (but unbolstered seats, and the 1093 engine), the trim was gradually upgraded, until on a B-reg, the Coupe S was launched.
An A reg should have:
1093/1272cc mechanical headed engine (crossover year for engine size).
Flat grey and black or dennis the menace seats
4-speed box
Yeah,I've got a brochure for 'The new Polo Coupe' dated 1983,and though it had the sports S interior,it was only available with the 1043cc engine - and simply called Polo Coupe.
I have a few brochures. I'll get a couple of scans up,and print dates,this afternoon.
Bluey is an A plate, was classed as a 1300 coupe and the first run of the sportier look before they changed a few minor things and called them S's, if you are lucky enough to find an even earlier one you could have a rear screen without a hole for the wiper which are really rare, (probably on a Y plate) although quite likely they will be the 1093 version. Bluey was registered in February 1984, i don't like him refered to as an S as he never was one :-D
IMO the early non S version and early coupe S's are the best, also a bit lighter :lol:
i'll list differences in case anyone is interested....
accellerator pedal is small and there is no rest plate underneath therefore the carpet is different
brake pads are postage stamp size (might want to upgrade them tend to be a bit scary!)
badges on the back are different, early ones didn't have the round Vw badge on the left, just say Volkswagen and no S badge of course on the pre S ones
door cards are a different design
seats are unbolstered and not height adjustable so really nice and low, i loved mine but they squeeked like hell and kept leaking the horse hair type stuffing!
no plastic sill trims - thank god as these are rust traps! also makes arches rare as hens teeth as they don't have any cut out bit
mechanical tappett engine and 4 speed gearbox - rev really well, very tough and a bit quicker
steering wheels are different, not the 3 spoke similar to GT ones
slight difference to the clocks i think although can't remember what my original ones looked like! don't think it had the red change gear marks for one.
some dash switches are different pictures, think stalks are different pictures as well
don't think i had intermittent rear wiper but that was an easy sort.
no twin headlight grill as standard
dash is a different plastic so a slightly different pattern on it, i prefer my early one - you can also get brown dashes!
seat belts were different, the tops are just metal and more triangular and so the parcel supports are different - the hole is smaller and later belts wont fit!
basically no real differences between the first non S and the badged ones but a lot between the early and later ones! probably forgotten a few so feel free to add to the listl just shows how anyone breaking an early one should offer the parts up :-)
I noticed alot of differences in the re-shell of my '88 with an '85 shell.
I've fitted the big accelerator pedal but still have the square brake and clutch pedals.
Different steering column,master cylinder,dash loom,very few things were the same. My rear belts are the early type,but front belts now the later type. The foot rest plate and later carpet are now there but weren't in the '85.
Even the bodyshell has differences beyond the bulkhead - the crease around the rear side windows is different!
There is a B reg one in my local scrappy.
Parts nicked for my old breadie:
- Black parcel shelf
- Front arches (The rare sort according to Liz)
- Front Splitter
- Clocks with Rev counter
- Centre Console
- Glovebox
- Boot carpet
- Window Mech
Parts in mt GT:
- Black and Grey stripped interior
- Black carpet
Parts in my Coupe S:
- Rubber sill covers inside the door
- Rear wiper motor
- Dash speaker grill
Thinks thats it, i may have more of it, i dont think anyone else has touched it :lol:
Its still there as well steadyly getting raped by me.
reverse light is different as well, so yeh when you come to think of it there isn't much the same!
i need a mint set of the plastic things the seat belt at the back goes through, the parcel shelf supports (coupe ones) if they are mint, and id really like an early set of door cards that are mainly vinyl with the bit of black and white fabric with red stripe, not the half and half ones, every set I've seen have been trashed :-( and basically anything early thats mint if you wouldn't mind looking?
I could also use a spare reverse light come to think of it, with the square light.
I will check it out for you Liz, I'm pretty sure the doorcards are half and half, the passenger door one is trashed the rest are fine iirc.
I know the steering wheel is still on it.
Shall i just remove everything on that list and post it up on here? It will proberly be crushed soon as all the panels are shafted.
good plan, just look for anything thats in good nick only one mk2 in my scrappy and its trashed although i do have spares of most bits its just finding really mint bits for Bluey really. oh i do really need a mk2 speedo cable if you can grab me that? and if there is a metal bottle on the carb get that as they are getting rare someone will want one of them as the plastic ones are fire hazards after all this time, so really should be replaced.
sorry slight thread hijack here :lol:
It OK as Yeti actually answered the original post.
We just got caught up in the geek knowledge haha
I will finish the car off next week then and let them crush it, its been there for 8mths now as i keep telling them not to crush it.
This brochure was printed in October '82 and shows only the 1.0 Coupe. Pics are of a mirrored LHD car - on Pirelli P8 tyres. This one has passenger mirror and rear wiper but i dont think they were standard. Also shows smaller early reverse lense.
They show the mechanical-head engine,and early suspension/brakes in a later brochure..
..before introducing this revamped model in '86.
Here's the crease in the rear quarter on my pre-'86. It's smoothed on post-'86 Coupes.
Edited by MikeyMK
never noticed the crease, I'll have to go compare mine!
I've got a mk2 coupe s :) wicked little car on a 88 plate
I want an early one! looks better with out the crease me thinks...
god damn, look at that motherfreaking pimp engine bay... vw were chroming stuff before most of the people on here were out of diapers, colour coded axle/drums, struts, epic pimpness
Edited by grungeisdead
Forgot i posted this.... I'm going to see it tomorrow now and have been told its a GT so am now very confused?
It might be one of the very few that slipped through the net so to speak.
Dealers over here apparently re-badged them as S's, as VW didn't deem it 'hot' enough to wear the GT badges as we didn't get the 75bhp GK engine that the GTs on the continent got due to our lack of a brake servo.
I'm abit confused, so it could be a GT rebadged as an S but without the 75bhp engine?
nope it will be a S with a GT badge on it, unless its left hand drive it will be the same as any coupe S or it was imported, I used to have a C plate that was right hand drive but imported to the UK in about '89 iirc the only difference other than a few odd trim mix and matches with different years was it only had rear lap belts :-) he was called 'Jim' and a wicked car, think he had seen a bit of life :lol:
on a plus side the mk2 GT badges are quite rare so might want to keep an eye on that, Bluey is wearing one :-)
Okay thanks. I'm probably going to buy it, its only done 79000 miles and has all paper work to proove. If i do ill get some pics up ASAP.
I supose its quite hard to put a price on it but say it was a 1.3 A reg coupe good condition with 79000 miles. what would i expect to pay?
Cheers :-D
Cheers :-D
Okay went and had look and a little drive today .Its a silver 1983 coupe 1.3 4 speed seems quite good not much rust but a few anoying bits missing (parcel shelf gear knob, timing belt cover and rear boot door ram thingy) and holes in the rear trim. Its got a GT steering wheel so iI guess thats where the confusion came from. The history isnt as good as it sounded 12 months MOT no tax they want £400 should i go for it? :? it would mean selling my 1990 1.3 5 speed breadvan :-(
