1 litre Mk 3
what temp does yours run at?
i have put a new thermostat and it seems to run around 80-90 where as it use to be 70 is this a problem?
80-90 is pretty normal i think :) My GT was running just over 90 I later found out the radiator had a small hole in :lol:
mine always runs cooler than id expect not moving above the 70 mark unless sat in traffic for over 5 mins
lewis, your thermostat was broken, which means it ran at low temps, now you changed it runs at optimal temp :)
my 6n2 is eaither 120c or 70c which ever i chose :p
^^ Correct, My old 1litre mark3 ran at 70, which is coblers. My 1.3 runs at 90 which is normal.
