BMW Mini Wheels on 6n
o.k I'm looking to fit these to my 6n, bit different from the crowd
R92 7-spoke Fin ET48 19.0lb (8.6kg)
Et is 48, the standard 6n et is around 35 isnt it, so if i fit 10 or 15mm spacers they should fit, am i correct or barking up the wrong tree?
16 inch wheels, on 195, 45, 16 toyo tyres is the plan, or if i stretch tyres what size should i use
Daz
  • Replies 21
  • Views 4.5k
You may need something like a 10mm spacer on it depending on how close to the suspension it is. How wide are they?
Centre bore is smaller on new mini wheels....
only by a mm, easy to dremel out and get them on.
if they arent very wide, i.e around 6.5j you could run 165/45s
yea the centre bores are 1mm narrower on bmw mini rims, the offset could be a problem tho! thats the only thing I'm kaking myself about! but mine are only 15"x5.5j so i wont have as many probs if any! fingers crossed for us both lol
thanks for replys guys, i think there 6.5j, they were free so i thought i would be different, so i might have to use the dremel to open up the bore, if that going to cause me problems at high speed if the bore is inaccurate or will it be o.k?
if i was you i would reccomend wobble bolts, i reckon they will be more secure than "retro fitting" wheels.
Just my 2p tho. Id also reccomend a 40 profile if your rollin on a polo, will help with arch clearance,
45 profile could cause a few issues if your thinking of lowering etc.
Luke
Luke
Wobble bolts won't do anything to help with the difference in centre bore sizes!
stud pattern the same 4x100
centre bore 57mm (vag 57.1mm but it makes a difference)
yer man is right a session with a dremel is the key. I'm running the pepperpot style ones on a mk2 with no problems, (cheers jon they are still tops)
Lardyb you runnin 175/50/15s if so were did u get em at mate? I don't think u have to be too accurate on the bore because you also have 4 studs holding the wheel in place, it might be worth looking into getting a metal engineer to bore em, would be a 5min job for the!
165/50/15 bridgestones
got them proper cheap off my tyres £32 each. what a result. must have been a mistake as I've never seen them that cheap again but they arrived.
if you can afford em deffo go for bridgies.
The centre bore of 0.1mm wont be a problem - especially as you'll need spacers anyway.
If trimming the centre bore,do not do it with a hand tool such as a Dremmel - it must be properly centred.
Why? the wheels are lug-centric anyway, half the wheels I've ran on my cars over the years have had a centre bore way larger than the vw centre bore and I've experienced no issues what so ever.
if the centre bore was so important to centre the wheel it would need to be a much higher tolerance, i.e. an interference fit. once you bolts are done up correctly the centre bore of the wheel probably doesnt even come into contact with the spigot.
Bit the bullet a mate of mine has them now, hes going to paint them for me, nice and lairy, thanks for all the replys guys, will post some pics when there on, wont be anytime soon tho,
got any pics of it m8, as I was looking to do the same thing on my mk3?
ere you go
^^ That looks the mutts!!!! :D I wish to steal your roof rack!
you can buy it?
£30 and it's yours. not sure on delivery as its a bit big to go in an envelope.
I'm in south wales, you nearby?
Bugger me that looks good! Just my luck I buy some n think they will be different n then u go n whore them! Now because of your dopeness everyone will want em! haha But mine are going on a 6n anyways so watch this space lol
cheers m8, they look really gd :D
so are mine, but mine are gonna be in you face with some serious stretch going on :badgrin:
tigz ran these on his polo as did one of my friends andy!
they look nice and suit the car well
