Not going fast around roundabouts no more !
This happend ealry to night as try to go little bit to fast around a roundabout and then the tyre comes off and i am going side ways on the roundabout pooing my pants :shock:
o and the tyre is sitting normal on the bak of the rim just show how small the tyres are for the rims :shock:
  • Replies 67
  • Views 6.8k
Eeeek! Not seen that happen in a while.
Mega stretch & fast cornering just don't mix!
Hope your ok tho?
Jon
Holy shit mate! I've never actually seen that happen to someone, how fast was you going?
Martin.
haha unlucky mate. :(
I cant go round any corners fast, my tyres will rub on the archers.
ye i am ok lucky.
Wasnt going that fast 45 on a wide roundabout tryin 2 keep up with my mates polo gti wen mine is only a 1.4 lol ..lucky stopped it from spinning out and rolled it slowly into tescos.
Then me and my mate had to jak the car up he pulled the tyre up over the valve and i tryed 2 pump it up and some how it went bak on!
Rhys
Quite lucky then. Glad alls well
Unlucky mate :(. I'm not a fan of stretching myself don't like the look but would like to run G60 steelies on lowered suspension although if that means I can't drive it completely I'll look at other options!
Edited by The Underdog
ye that is the problem befor those tyres i had 195 tyres on my car
rubbed all the time and i dint have any spacers on the bak and i wasent as low.
now i got 20mm spacers on the bak and 15mm spacers on the front and hell of a lot lower and it dosent rub :-D that is how much the stretch tyres helped but the risk is the tyre coming off which it did :-(
That second picture looks shit!
y becoz of how low it is
Yeah...lovely wheels and paint...just a bit OTT on the drop-age.
ye i have raised the back up a little now so it aint as low coz the rim is self was hitting the arch :-(
EEEEK! Bet it looks all the better for it now :)
stretch is safe blud, i read it on the internet!!!!!!!
bet that gave you a brown pants moment! suprised there havnt been more occurances of this tbh, especially as people seem to be putting bigger and bigger stretches on their tyres. its almost like the fad for big wheels back in the late 90s
run more psi in the tyre...
i only had my 165/40's pop off when i hit a pot hole.. am guessing the tarmac got stuck inbetween wheel and tyre
Seriously.
Stretch is shit.
how are your rims not foooocked ??
I ran mine at 32psi at the front, same size wheel and tyre combo. Handling was rubbish compared to before (165/50/15's) still drove it hard a few times but never had my tyre fall off. Hit a few potholes too, good to know rs's are quite strong.
This is why I don't want stretch on my 20vt! What's the point in running big power and then putting less tread on the tarmac first of all... then this does happen!!!
Ye think what must of happened hit pot hole lost loads of psi and then went bit sharp around a roundabput and it poped off
The rim is fine some how dint even touch the floor thank god
ye normally run these at 32-34 psi better check them every day now make sure this dont happen agin and not even try 2 go fast :oops:
Ye steve your rite dont think it would be wise to run big power on stretched tyres mine is only 75bhp and the tyre came offf. The feel from them is horrible compaird to 195/40 i had :?
Rhys
Rhys
So you're running 165/45's on 7J? I was planning to run my 195's on 8j to give a decent look but will still be sensible... I personally don't like the serious stretch look where you can actually see the edge of the wheel... looks pooh.
:lol:
ye mine are 165/40R16
195 on 8 j that is a nice stretch mine is just stupid got the tyres so cheap so i thought it be worth ago.. was going 2 try and fit 35 mm spacers on the bak is well.
another string to the bow of stretched tyres... and why it's dumb!
wide wheels are for better traction!
Exept that wider tyres dont mean more traction, technically your contact patch stays the same.
