Not going fast around roundabouts no more !
Exept that wider tyres dont mean more traction, technically your contact patch stays the same.
Come again???
So a 225 tyre on an 8J has the same contact patch of a 175 tyre on an 8j??? I think not!
Unless i'm missing something!
  • Replies 67
  • Views 6.8k
wide wheels are for better traction!
Not really, the contact patch will be pretty much the same size. Wide wheels (or wide tyres) are just more efficient at cooling themselves.
beat me to it tommo and yes steve, you must be missing something
:lol:
Well if it's the same diameter then a wider tyre MUST give a bigger contact patch!!!
I've rolled stretched tyres on both cars covering roughly 30k. Not one problem
Funny how a back one popped off. I would have expected a front to come off...Maybe the pressure was abit low init?
How much of a stretch? Wheel size / tyre size?
I'm intruiged as I want to go 8j all round i think and a small stretch is a must as 225's all round will look crap!
ran 175's on 7j's for probably more like 20k
On my GTi i have 185 45's on a 8 and on the 7.5's - covered 20k
225 will be nothing!!
Nice bit of stretch on the 8's. Just nice. fronts arnt as stretched but still look cool
:lol:
Its to do with the pressure. So 30psi means 30 pounds per square inch. So depending on the weight on that corner of your car, the contact patch will adjust in size accordingly, whatever size your tyre is. So at 30PSI, if there is 90lbs of pressure on your tyre, the contact patch will be 3 square inches, regardless of the tyre size.
So you have to run a lower pressure to increase the contact patch.
The reason wider tyres give more grip is because they can be made of a softer compound, and they dont overheat because the sidewall is deflecting less because the contact patch is very long and thin, instead of being squarer like it would be with a narrower tyre.
Edited by Tommo32
Oh I know... that's what i meant! It'd look crap!
:lol:
Fair do's mate! That makes sense! Thanks! :-D
But you are still right, a wider tyre would give more grip.
I've got 8's on the front..
I could run 175/50's or my 195/45's..
Both would be basically the same modest amount of stretch, but if the tyres are the same brand / model etc, the 195's would have more grip due to the wider contact patch..
It's all about the width for the car.. i could run 10's all round with 225/40's...
225 is a huge contact patch for little Polo but if it has small sidewalls stretched then it's still just as likely to break grip under hard cornering and make the car slide, or hit a pot hole and pop the tyre off...
I don't agree here, as has been said already, the contact patch will be the same size. :roll:
hes not saying it will be bigger! hes saying it will be wider, which is true
click the link and learn why! (the relevant info is about half way down)
http://www.carbibles.com/tire_bible_pg2.html
Another reason to stop going so fast around roundabouts is because it causes problems for traffic trying to pull out when they have such short notice of having to give way,and this gives the authorities the green light to install traffic lights on roundabouts - as is happening here,and subsequently jamming the place up.
Atleast you got the cows!
:lol:
low profile tyres are prone to doing this and probably stretch tyres.
won't stop me fitting them though :)
165mm and 195mm aren't the same..
This makes no sense lol.
It cant possibly be the same no matter how big lol
If they have the same contact area then ill fuck my cat!
I'm glad others thought the same as me! :lol:
Don't fuck your cat though!!!!
Hot rods and stuff have massive wide tires on the drive wheels and tiny ones at the front.
If they both had the same contact area there would be no point. they could just have the small ones all round.
:p
I'm confused now....
I said that on my 8j wheels, i could have (for example) a 175/50 or a 195/45..
Both would have basically the same amount of STRETCH but not the same contact patch (obviously there's a 20mm difference).
Then you disagreed, saying the contact path will the same..
The B-Shaw posted that pic and you agreed :?
