Not going fast around roundabouts no more !
20mm in width not size.
Hotrods dont use the same pressure in these tyres, and the size is for cooling.
Can't be arsed arguing this just read the carbibles link...
  • Replies 67
  • Views 6.8k
I'm glad others thought the same as me! :lol:
I'm confused now....
I said that on my 8j wheels, i could have (for example) a 175/50 or a 195/45..
Both would have basically the same amount of STRETCH but not the same contact patch (obviously there's a 20mm difference).
Then you disagreed, saying the contact path will the same..
The B-Shaw posted that pic and you agreed :?
Come again!? Read through the topic again and come back to me! :lol:
I said..
On an 8 inch wide wheel, i could have a 175/50 tyre, or a 195/45 tyre.
Both would have basically the same amount of STRETCH but not the same CONTACT PATCH.
Then someone disagreed with that..
I said..
Yeah, the contact patch would be different, it would be the same amount of area, just a bit longer and thinner with the wider tyres. I think people got confused thinking that you meant the contact patch would be bigger.
People should either read the link posted or what I wrote towards the bottom of page 2. Its science, its not really up for debate! :shock:
Imagine putting your bicycle wheel on your car, with 30psi in. Now, the tyre would have a big flat spot in the bottom would it not? even with the same amount of pressure in there would be much more deflection due to the thinner tyre trying to achieve the same contact patch as if it was your normal car tyre. 30PSI is 30 pounds per square inch, so that is your contact patch size in relation to the weight on the tyre. Nothing to do with the width of the tyre.
I see what you mean..
All I'm saying is, realistically, with the exact same wheel, you'd have more rubber on the road with a 195 than a 175..
With the sidewall stretched excessively, there is no 'give' so the tyre is more likely to lose grip when cornering, which is just what i was trying to say originally.. that 20mm extra tyre width would make it less likely to lose grip.
I said..
Yeah and that wasn't me :lol:
I got confused :lol:
You confused the fcuk outta me! :lol:
i dont think what your saying about contact patch is 100% correct actually
There is a point obviously where severely wider tyres creates a problem because the car is just too light and the mass is distributed across too wide an area (hence why in the snow and ice you want thinner tyres) and why my beach buggy 540kg and 285 wide tyres out back...really does not like the rain
and when you talk about contact patch you are forgetting that this is constantly changing whilst you drive, and the second you turn a corner and redistribute the force across the tyre the contact patch changes in size and shape.
I'm sure someone will argue, but it really is not as simple as i think you are making out
At the end of the day for dry weather grip wider tyres are better. I'm not saying they have more tread on the road but they're do give more grip!
That is so obvious. Of course wider tyres will provide more grip as there is more contact on the road.
FPMSL! You obviously haven't read this thread! Read it! :lol:
You are of the same opinion as i was originally. BUT...
From what I understand all tyres of the same pressure have the same contact patch (no more/less contact to the road).
But the way the wider tyre releases heat so doesn't go rock hard and thin when hot is the reason why it grips better.
I ran standard 4.5" polo steelies on my mk3 now runnin 6" lupo steelies and it handles better and goes round corners better. I'm no scientologist but if something happens to me I believe it, not before :p
Stop driving like a cock on roundabouts!
lol ..
I would go for 175's on a 7J and 195's on a 8J ..
Drove my car to death on those wheel tyre combinations with no trouble
another string to the bow of stretched tyres... and why it's dumb!
wide wheels are for better traction!
but people wouldnt put 9j rims on their car with ballon tyres just so it handled worse would they ? wider wheels doesnt mean better handling !
as for the power down on stretched tyres etc , its all down to personal choice , if you want to go for pure looks , get mad stretch , if you like hammering it round bends , get a little stretch or none , if your runnin mad power dont go for stretch atall , easy enough really .........
unless you're building a drift car.. 500hp and stretch..
So now kids:
This is why we DON'T drive like a tit whilst running stretch.
Stretch is perfectly fine for its uses if used in the correct manner. It IS NOT intended to be thrashed around, if you want to do that, put on the correct tyre for the wheel and flare your arches or something.
Stretch IS intended to aid with fitting wheels not designed for a car, especially when lowered. Sometimes for looks, or for drifting.
