painting my full car
right am wonting to paint my full car just wondering how to get it done? any one no were to get good paint from?
and should i use a airgun ? do i need to sand out down and primer ....
  • Replies 13
  • Views 1.6k
if you havnt done this sort of thing before... which i suspect you havnt... i would recommend take it to a body shop.
As above, by the sounds of it you are a complete n00b to the painting world - the best way would be to pay someone who knows what they are doing. Otherwise it will look shite
From how you've asked I'd say don't go anywhere near any painting equipment until you know what your doing. Lol. I've helped my mate paint a few cars now and theres more to it than just scuffing it up and painting it!!
i have paint quite a few stuff in my time just wundering what to do before i paint it
How can you have painted stuff but not know what to do before?
Its not an easy job mate. And if you don't know what your doing you will completely mess it up
You need practise before diving into a full respray.
Use the search button also. Its been answered a million times on here already.
It depends what you want with your car
If you wanna have a show standard gleaming car, your gonna need around £1600 minimum for a good spray job from a pro in the same colour.
If you want your car to look a mess and just spray for a laugh, spend about 50 quid on some matte rattle cans from Halfords
i just noticed you've got an openair... that'll have to come out otherwise you'll get a bad edge, causing the paint to flake away... and you'll get paint all over it. and you dont wanna buy a new cloth. they're about £500 new from VW!
Edited by andypandy
'if you can piss, you can paint'
the skill is in the preparation.
like has been said above - it depends what kind of finished job you want, as this will determine how much preparation you put in beforehand, whether you take off everything or just crudely mask it up.. whether you use a ventilated spraying oven or not.
and that's not even touching on the type of paint you use, if you are planning on having it sprayed with anything other than halfrauds rattle cans then if I were you I would get it done professionally.
What are you talking about haha?
Have you ever painted anything? Like a hole car?
Its not all in the prep. a lot is in the prep, but not all.
ye am up for a bit of a rat look .like purple on some silver borbets
painting isnt that hard, and diy doesnt mean you have to go matt or ratty (and yes i have painted a couple of cars with rattle can)
the most important thing is the prep, anyone with half an ounce of sense and a bit of practice can lay paint down without making a total mess.
first thing to do is check the car over and see what prep need doing, any rust or dents you want to remove etc. if the car is rust free, all one colour and doesnt have any major dents, you dont really need to prime, just make sure you key the old paint well with a sctotchpad or similar.
lay the colour on, do worry to much if you get orange peel as this will flat out, but try to avoid runs especially if using metallic or pearl paints.
once your happy with the colour coat, give it 2 or 3 coats of laquer and leave it like that for a week or so to harden.
once hard you can flat out any imperfections with fine wet or dry paper, then polish it up (would recommend a da polisher for this)
do not wax the paint straight away, as fresh paint doesnt require it (in fact it can stop the paint from going off by trapping the solvents)
after about a month you should be safe to wax the fresh paint.
heres one i did earlier, done with rattle cans outside with no special tools or owt and the paint was polished up by hand. (bottom half of the car, although i did do the complete rear quarter as it had some rust on it (both paints were metalics too)
heres a wing i did for my old mk2, again rattled, but sprayed indoors and no laquer (not required on non met. paint)
But to get paint even and with no orange peel... You need to be good!
Yep, you could paint it and it would be ok from a distance. but look closely and you would see.
When I did my car, I wouldn't say it was difficult. but I wouldn't say it was easy. Keeping it even is the most difficult part. especially on the coats after the 1st as you cant see where you have just sprayed as clearly as on the 1st coat.
Keeping a good speed going too so the 1st coat doesn't dry too much before you get the 2nd coat. This more so applies if you are doing it all at once. You need to be quick but not too quick you make a mess of things. and not too slow that it all goes to pot and you need to wait for it to dry properly and start over. This doesn't apply with matt paints as much.
I didn't prime mine all over but it is a good idea. If you don't put enough coats on and you have mismatching paint underneath it will show through. Which is where its good to have it all one colour underneath.
800grit is a good all rounder for keying the paint. Anything much lower and you start seeing scratch marks. Anything higher and it takes longer. At least when I did it that was the case.
Get some decent panel wipe too for getting rid of the crap. The surface needs to be super clean before you apply the paint.
Oh and Jon, Thats a bloody good job there mate!
