damn sticky windows...
right, now i know that on the mk4 there seems to be problems with windows getting either stuck up or down.... my bro's missis car suffers, countless peeps on here have suffered!
from the search function, most i can sus is that a trip to the scrappy and a 2nd hand window motor will solve this, but mine seems to be different? its the rubber round the windows (i think) casuing them to stick?
the passenger one goes down fine, but struggles to go up... i often have to lift it a bit, then wind it a bit, then pull and so on and so forth... this problem seems to be worse in the rain?
the drivers side wont go down, hasn't for ages (since i last wrote a thread similar to this early in the year!) but i know the motor draws a current when i press the button?
This is massivly gay as i pretty much can't use the windows, and i need to smoke!
all help appreciated!
take the seals off and give them a wash then, although smoking is bad. So stop smoking and they might open for you :-)
i tried coaxin the old girl by giving her a relaxing bath at the weekend but to no avail...
quiting smoking soon anyway due to an operation, but it's still gay not being able to open the drivers window... especially at public car parks with barriers! :roll:
silicone spray lube in the rubber seals as putting the window up and down solved it for me like matey
had the same problem with passenger window not budging but drawing power.....
take off the door card and tap the motor with a hammer or similar
try takin out the top right bolt that hold the runner on out and put 2 washers between the runner and the door and put 1 washer in the bottom left i think thats right it worked on mine
