Jarno6N
Just had to change my t shirt after dribbling so much over your car!! Its absolute stunning this is properly the best 6n ever seen,the amount of attention to detail is amazing!!! Amazing build
  • Replies 172
  • Views 47.3k
Cheers everyone for the positive comments! Propper boost for keeping the project up and running :)
And yes, it's meant for my 6N2 dash, won't fit a 6N dash :(
  • 3 months later...
The engine where did you get the air filter connector that connects the blue hose to the throttle body as i am in need of one, also what is the best way to tune my car to give it a bit of uummpphhh besides changing th engine?
wowthatsonemassivelongrunonsentenceihopethatjarnowillanswerthatonehaha.
The lenght of the sentence doesn't bother, but damn, did you have to quote the entire first post? :lol: but it's a mk3 Golf 1.8 8v spi unit, be aware, there are 2 version, 1 that will fit a mk4 Polo 1.3 spi, and the other that will fit the mk3 Polo 1.3 spi!
yeh have u got a code for urs unit? and soz :L didnt realise till i posted it :D couldnt find a seperate post with the pic on :D
No problem mate, but sorry, no item-code, sold it a while ago and never noted the code :(
seen a lot of dutch registered cars driving around near me this morning, dutch invasion?
  • 7 months later...
Well, it's been a long, long, very long time since I've updated on here, so a small summary of the stuff I did to the 6N in the past 1,5 year. Finally the car has been on the road since June 2010 again, it's not finished yet, but it's seen the road again! 8-)
Old engine went out, so time for some coffee
I think I saw one fly over the cuckoo's nest:
Then started stripping down the donor 20vT, which was to be completely rebuild with new bearings, rings, gaskets, etc. etc.
Test fitting it in the 6N:
First dilemma's popped up, had to do some modifications, old and new support on chassis:
And removed some stuff I wasn't going to use anymore at the same time:
Finally it hung in straight and even:
At first I wanted to just use the standard K03, but since I already had a KMS standalone-motormanagement ECU laying around, the choice became obvious -> go big or go home!
Then I got an offer I couldn't refuse, a friend of mine offered me a Garrett including the external wastegate kit, of which the wastegate housing and turbo exhausthousing were already flowed. So I bought that for the 20vT!
To give an impression, on the right a MHI 16T (not the smallest either), on the right my Garrett:
And of course it had to be obvious that a bigger turbo was installed, so it had to be seen on the engine. Therefore we choose a spot right above the engine!
Snug fit!
Measured it all, and had the manifold custom made from stainless steel, first only tack welded so we could trial fit it:
Some readjustments were needed, but nothing crazy. Then it was welded up and ball-polished, for bling and smoothness on the inside (better flow):
Turbo back on, also had the valvecover and inletmanifold ball-polished:
Autotechniek Leenders made the custom loom in the meantime :lol: :
Ready for trialfit!:
Starting sanding down the enginebay, smoothed the stroke kit and the brackets I wasn't going to use anymore. Ready for it's primer in the booth at bij Autotechniek Leenders:
And sanding, sanding, sanding:
Time for colour:
Toen kon alles er weer langzaampjes in, rembekrachtiger weer netjes gemaakt:
Engine and gearbox got build back in the meantime in the workshop of Autotechniek Leenders, and put back in the car:
Garrett is on again, close, but he won't touch the firewall, did I say snug fit yet?
Then the intercooler piping could be made, minimal use of silicon to prevent loss in boost, plus metal can be ballpolished ;)
Time to custom make the exhaust, using the original catalic convertor, not sure if the cat stays on, but just for now it's on, and maybe I'll get a 200cpi cat lateron.
Van turbo tot einddemper naast de auto gelegd:
Ready for fitting back:
Heatwrap on the downpipe:
Turbo housing was cast, looked like shit to be honoust:
So I polished it:
Got the intercooler piping back from ballpolishing, smooth on the out- and inside :D
In the meantime Autotechniek Leenders:
-timed my new camshafts:
-fitted the stronger fuelpump:
-zinc-coated the bits and pieces:
-fitted the biggest master cilinder we could fit:
-and ballpolished the alternator housing, bracket etc.:
Found a spot for my airfilter, and got a pipe connecting it to the turbo made:
And it's nose is back on again in the workshop at Autotechniek Leenders:
Bought me Audi A6 winterwheels in the meantime:
Got them redrilled to 4x100, and polished at Felgenpoliererei Gescher:
165-40-16 Kumho's on:
Smoked the headlights:
Bought me a new mk6 Golf GTD steeringwheel:
And how it looked last Saturday evening, ready for it's debute at the first VW event over here in Holland:
Some minor stuff needs to be done now, but it finally drives again, now the first 500km, and then it's time for finetuning the standalone motormangement ECU at Hulsen Turbo Tuning on the dyno! :D
Haha, thanks Polomon, but it's not the first 6N 20vT we've build ;) almost all things that went wrong on the build of the 6N bi-turbo of my mate, were known now, so we could do all things right in the first go ;) which made it a lot easier. It was all the custom stuff, boostpiping, exhaust, manifolds, etc. that took a lot of time, but was worth it in the end!
Some snaps from last Sunday's event it premiered at:
Mint, love it mate
8-) fiiiiiiiiiiiiiiiiinally
I wouldnt have been as patient as you were man..no way haha
I'm glad you changed your steering wheel
Mate that is crazy . love them rimz . engine looks sweet as to bud . verry very nice car . Dave
Holy sweet mother of crap. That is incredible. Attention to detail is crazy- How come you chose not to move the battery dude?
And again absolutely stunning <3
Perfect, literally so so so nice!
What spoiler is that? :)
Smooth , Air and now a 20VT ....just full of win this polo...awesome work mate =D
Cheers for the nice remarks people, they're well appreciated! :-D
Well, if I would have moved it to the bad, it would have left a giant empty spot. Boostpipe and big filter on the left of the engine, empty spot on the right = not the prettiest look in my opinion, so I left it there, and tried to use as much OEM VW parts to make it fit (for instance crafted a custom fuseboxmounting thingy, to support the OEM 6N fusbox on the battery). Now the bay is evenly filled up with sheit, which gives it a nicer look in my opinion :lol:
I find the not overly minimal look in the bay pleasing. Looks more like it should have come out the factory that way..... well kind of.
Excellent stuff. What kind of power are you expecting from this once all running in and tweaking has been done?
8-)
That's is fucking out this world buddy love it <3 I want a 20v now :(
That's exactly what I was aiming for, a look that could have been from the factory, with attention to detail and not too much of a minimalistic look that's been so overpopural recent years.
Powerfigures should be in the 300+bhp range, but that's totally dependent on how much of a restriction the OEM 20v catalyc converter will be. I want to try it with the OEM item first, since that's the most legal and easiest option for APK (Dutch MOT). But if it holds performance back below 300bhp, it'll just have to go and make way for a 200cpi stainless version ;)
You and Rin been ballpolishing? Double dutch rudder?
:shock:
Looking great Jarno, need to catch up soon when you are in UK
