Mk4 (?) Buying advice please
Hi Guys, I'm just visiting from Clubgti to pester you for some advice.
A friend would like to buy a Polo Mk4 (I think it's mk4, circa 1995 :? ) probably a smaller engined version, no bigger than 1.4.
What I'd like to know is what are the common faults on Polos of that age? I know all the usual used car checks but was after any Polo specific faults/problems to be wary of.
Also is £500 a realistic budget for a decent car of that age?
Thanks for your help
main thing to check for with them is rust. they rust like crazy on sills, door bottoms, arches, suspension mounting points.
also watch out for dodgy ignition switches, shonky electric windows, that fall into the door. thermostats are prone to failing and giving headgasket failure like symtoms (sometime a crafty way to bag a bargain) gearbox can throw up issues (make sure it is smooth on the gearchange), as can the clutch release bearing. pedal boxes have also been know to snap too!
oh and a dodgy idle will normally be caused by a dirty throttle body (very very common prob with them)
other than that they are a pretty reasonable little car, if a little bland
And 500 is a reasonable price I'd think, maybe a little more for a low mileage one in top condition.
Yeah main thing on Mk4's is the gearbox, i've had mk4's that didn't slip in to 1st or 5th that great but its very common and mine never got worse but make sure it isn't too bad. I've just bought a mk4 and the gearbox is spot on so they are out there! hehe
Other more minor things that go temperamental are the electric windows and the central locking. But these could be haggling points. A replacement 2nd hand central locking motor is usually about a tenner...but the sellers might not know that.
I've had a few mk4's and thats all i found to be wrong (apart from the 16 valvers which can have bunged up throttle body's aswell)
You can always get mk4's for £500 but for a couple hundred extra you'd get a much better one.
Edited by DubLass
Thanks guys.
DubLass are you the same DubLass that used to post on Clubgti
..unless i posted something offensive or you stalked me...then yeah :-)
