damage to sill
Helllo
I was wondering if anybody could advise me on how to repair a damage sill. the damage was caused by post that had been left flattened in the road, it has bent bent the sill quite bad.
Any ideas please let me know
thanks
  • Replies 8
  • Views 1.5k
I've got an issue with my sill also..
been to body shop 2 ways of fixing..
lead filling where they just fill the hole and paint over it.
or the second option was to weld metal rods to the sill and then pull them out...
so its straight ish again.. cut the rods off and skim over the top with filler and paint
well as mine is jus dented, quite bad i might got for the welding option and see how it goes
i was going to suggest welding nuts to the dented area and use a slide hammer screwed into the nuts to pull the dent out, then grind the nuts off, skim of filler then paint it.
I might have a try at that tbf cheers
I dented my sill a little bit when my car fell off a pair of jacks....
My old man does car body repair and said he would rub it down to bare metal, spot weld a small rivet type thing to the sill, then use a slide hammer to knock it out, filler, sand and paint it back.
Okay was it alot of hard work, and would it cost loads if done by a garage. Or would it be better to just put skirts on to cover it?
depending on decent garage / bodyshop you'll be looking at £200+
Even if you put side skirts on it you'll still have to buy them and have them painted so you might as well just get the job done properly.
