PWR barrel chargecooler
As above I've got a PWR barrel charge cooler for sale.
It's in brilliant condition only having been on a car for less than 500 miles.
This charge cooler is 4"x6", 400cfm and is rated to 280bhp.
Ideal for g40, g60 or anything else force induced.
With a chargecooler you will be able to reduce the air resistance and shorten the distance from the boost outlet to the throttle body.
These pwr barrel charge coolers are about as good as it gets charge cooler wise 8-)
Pic,
Price: £180 + £5 postage if needed (Brand new these chargecoolers cost £245)
  • Views 238
I assume all you need is some piping, pump of some description and a tank?
Yeah sort of, you need a pump, piping, tank and a radiator to dissipate the heat.
To be honest the could work really well on a mk3 as if you don't have a intercooler in the way then you could fit a really sizeable radiator in there :)
