momo boss 6n
got the old wheel off, do i need to take off the plastic thing with the 3 holes in it. and how do i wire it up?????????????????
please help
  • Views 961
You've taken your wheel off, what you should see is the brass ring, making sure the wheels are straight and put the boss on, so where it says "top" is at the top, then take the earth wire and the live wire and connect them as shown in the diagram with your horn once you have bolted on your wheel by pulling them through the middle of the horn hole and connect them to the horn then push it into the middle, remembering the metal ring going inbetween the boss and the wheel. Turn on the ignition and it should work, if not check your connections.
Easy enough to do, if I get some time I will take mine apart today and put a picture or 2 up for you, let me know how you get on.
ill prob give it another go tomorrow cos I'm pretty much pissd now lol... have settled for the wheel on, no horn, and plastic thing with three holes hangin out the bottom... knocks the indicators off perfect tho :)
ill give it another go tomorrow and let you know how i get on
thanks for the help :)
glen
Just wondering what this piece of plastic with 3 holes in is because I don't have one, I have the factory mounting point, then the boss with the gator round it, the metal mounting disc that goes on top with the horn button sitting in it and small metal clip ring behind to hold it in and the wheel bolted on top of it all.
Looked at the wiring but my camera's dead so I couldn't take a picture but you should have the black wire at the base of the boss which you connect to the back of the horn, make sure its on the connector that doesnt have the ground symbol next to it, then plug the ground wire to the horn connector with the ground connector and to the small metal mounting disc, once bolted it should be fine, before you bolt it all on you can test it by putting the ignition on and holding the metal mount against the boss then pressing the horn.
Other then that I am out of knowledge for now, I'll try to figure out what else it could be but I don't understand where this plastic big has come from :?
