spray door handles?
hi guys
looking for ways to give my polo a better look was wondering how hard it is to code the door handles?
and if there is a guide or something
=D
  • Replies 13
  • Views 1.8k
Not hard really, be easiest to take them out first. Key them up with some 800 wet and dry. Clean them off using some sort of solvent to get rid of any road film, silicon etc. Plastic prime them. And then spray. :D
Aye, it's simple. If you want to be anal like me, get some 200 wet and dry and smooth the handles. Also, if you're doing this outside, don't get obsessed with details and acknowledge that you probably won't be able to get them perfect.
Edited by MehMan
thanks guys shall have a look =D
just wondering what other little mods and things (not costing lots) could i do my self
to improve the look of my 6n?
Bump strip removal, roof strips from a 6n2, rear lights from a 6n2.
http://premium1.uploadit.org/ollieryan//6nroofstrips.pdf
did bump strips last week and shall look at other things thanks =D
just wondering where that guide came from as i looked at lowdub.com and it dident work =(
Edited by Proxy
UK polos had them in the DIY section. There are a few things there that might give you a hand. People also like to dewiper the rear window. Don't like that. Also, if you want to lower your car, you can do some with standard shocks and lowering springs. Ben_reza has his polo on 60/40 springs and standard shocks and it seems to work. you can get spring compressors from ebay for pennies.
Edited by MehMan
nice one thanks was wondering how well spraying the roof strips that are already on the 6n would go might work as long as prime it all first?
also is this the kinda thing you mean to lower it (Ebay springs)
yer i will keep the back wiper at least till summer again lol
=D
thanks man been big help
Well, they're rubber, so I don't think it's a good idea. The paint will crack, the rubber will crack and you'll need a new set of roof strips.
And yep, those kinds of springs. Although, I think H&R would be the better, more reknown option. Or some other brand. Though, they are just springs, so I can't imagine there being a HUGE difference between manufacturers as they must all follow a minimum standard and I doubt they have a different number of coils.
ok cool thanks for the help i shall have a look for some H&R also are they easy to fit your self or best to get some where to do it for you?
thanks so i guess it would be the same but i would just change the springs and put the same part back on
dont look to hard would just get some help and spend the day on it.
thanks
Aye, you need some spring compressors(you can get them cheap from ebay), a decent spanner and socket set and a haynes manual wouldn't be a bad idea. Just do beware, that it has been said that using lowering springs on standard shocks can lead to premature wear, however ben_reza's been running his 6n with 60/40 springs for a while now and it seems to work well.
right well it will go on the list but looking on ebay for shocks are about 3x as much money so might leave it for now until i have other things done but thanks for the help btw here is a photo of how its looking at the mo.
Little Polo
