How to Anchor my harnesses?
Hi
I’m looking to put some 4 point harnesses in my 3 door mk4/6n polo.
I would like to keep the rear seats
Is this possible?
If so, how should I anchor my harnesses to avoid making it too difficult for people to get in the back?
  • Views 957
1 in the rear seat belt anchore, one to the left and to the right of you
gotta get rid of rear seats mate if you want these
can i not anchor my harnesses under the front chairs?
Nah - the forces involved if you were to crash would hurt you, a lot!
IIRC the rear bits need to be above your shoulders, otherwise it will pull down on you and can break seat/ruin your back
Correct, badly fitted harnesses can brake your back in an accident. The rear straps should not be mounted no more than 45Deg from horizontal so often even the rear belt points are no good. THey should really be fitted to a harness bar between the rear struts or to a cage.
nick
