Turbo remapping with PPP at the weekend
Had a very productive weekend getting my ECU map properly sorted out for running lots of boost with the turbo.
Started off at the PPP headquarters in Cheshire on Friday afternoon and saturday morning to get a vernier pulley setup, reset ignition timing and do some general checking over to make sure everything is in top shape before turning up boost and doing some final mapping.
In the PPP unit.
Dial gauge measuring TDC to setup the vernier. In the end the vernier didn't need much adjustment but it's now totally spot on. Ignition timing needing moving a fair bit after this though to get it set to it's factory base timing. There's no point trying to do ignition remapping when the dizzy base setting isn't spot on.
Then I even gave the car a wash which is a rare treat for it.
After that and after going for a few beers in Crewe (can't say I recommend the Wetherspoons there though, awful beer) on Friday night. I set off for round two on saturday afternoon.
Saturday evening and all day Sunday were spent down at the PPP midlands office/workshop near Leamington Spa for remapping. We'd already done this before and Andy had got the fuelling pretty spot on when we went out at the polo show on sunday and did some road mapping. The main aim for this weekend was to wind the boost up to my target of 20psi, switch the aquamist on, make some more tweaks to the fuel map (since we'd be hitting some load points we'd not seen before in my car with the increased boost pressure) and then do some ignition mapping. It's actually much, much better to do ignition mapping on a dyno because on the road it's very difficult to maintain steady load and do clean sweeps through the rev range, especially since on bumpy lanes my car is very bouncy with it's suspension more set for the track than poorly maintained country lanes! Anyway since the rolling road we like to use was out of action for a while (and others wanting silly money per hour to use) we decided to just spend more time getting ignition as sorted as possible on the road. Then the plan is to do just a single hour on the rollers before the RR day in a couple of weeks.
So we spent the day doing this and it went very well despite the weather being a bit shitty to start with. Andy got the job sorted well and was frantically adjusting advance figures while I was trying to listen to his instructions at the same time as trying not to bump-steer into ditches.
So by the end of sunday I'm really happy with what PPP have achieved this weekend and Andy experience with just knowing what numbers to put in where are what makes it possible. It doesn't matter how much money you spend on fancy mapping gear it'll take you a very long time to get anywhere without the experience of just knowing how much ignition advance to dial in or how much more or less fuel is required at certain points etc...
Unfortunately didn't really get any pics of remapping since we were just too busy but here are the graphs of the fuel and ignition maps we ended up with. They don't really tell you anything but it's good to see how nice & smooth and progressive they've turned out to be, what I've found is that it's actually relatively straight forward to get the full throttle, high power mapping done but where the work is, is in getting all the million and one combinations of light load, partial throttle stuff done which turns a car which is undriveable on the road to being basically as smooth as you'd expect a standard car to be.
So the next step is an hour on the rollers to do some final ignition tweaks and just a general check up, then to see what it makes at the RR day in a fortnight. The proof will be in the pudding but I know already that on the road it's bloody rapid.
  • Replies 8
  • Views 1.7k
Sounds brilliant, enjoy the motor mate I know I would :). Well done to Andy @ PPP too, you put in a good advert for them here (although I can see why, they deserve it :D).
well both Yoof & Andy really, they both put lots of effort in this weekend.
Yeah I know it's bordering on an advert for them but they've both done a great job so I think they deserve a bit of pimping :-D
Sounds spot on chap.
I'd certainly use their experience were I not a silly distance away :(
it was a 5 hour round trip for me to Andy's. Worth the trip as I don't trust anyone else really. Yoofs unit is a lot closer to me but it was easier for andy for me to drive down there since there was nothing mechanical needing doing to the car after the vernier setup at yoof's
How much does all this work cost?
£300, including a pre-mapping health-check and setup. Can map on a dyno too - at the owner's cost.
I think mine needs some spanners thrown at it yet but if I can get someone to do mine, I'll let you know ;)
(think the pulley seal on the chargers leaking again!)
Edited by stresshead
That's really good, most places with a dyno want £400+!!!!
did it take you long to learn how to map things?
