Tell me about 2000 1.4 TDI's
Been offered one and wondered what they're like.
Also best prices people have got for a Cambelt + water pump change.
Nick
  • Replies 17
  • Views 3.2k
Anyone?
dont know much about the polo tdi's. I've had a shot in an audi a2 with the 1.4 tdi 3 cylinder engine and its pretty brilliant. suprising amount of power and cracking mpg.
not sure if its the same engine though, u'd best check with someone who knows :D
A few people I know have these engines.
Really good engines infact and can push over 100hp with a remap.
all i know is 75bhp standard 100bhp with a map lol
Yep :D
The one I've been offered is a 2001 X reg with 119,000 miles. It's been a Cat C and the shell is very slightly bent at the rear (Boot floor and rear door needs slamming) but it's all rearward of the suspension (It's been checked for allignment). It needs a new cambelt and water pump to be on the safe side. Only mod is lowered 40mm on spax shocks and springs.
THis would be a straight swap for my Corrado 16v.
Just wanted to know what they're like to live with on a daily basis and if they're OK to drive.
nick
Top cars i've had a lupo tdi and a polo tdi loved every minute of both loads of torque and a very practical daily. Sister in law has an a2 1.4 tdi with 195k on the clock still going strong.
Found this - Taken off whatcar.com for ''Volkswagen Polo Hatchback 1.4 TDI PD S 3dr''
Engine
Cubic capacity: 1422
Cylinders: 3
Max Power (bhp/rpm): 74/4000
Max Torque (lb ft/rpm): 144/2200
Town mpg: 48.7
Out of Town mpg: 76.3
Average mpg: 62.8
Fuel: Diesel
Running costs:
Insurance group: 6
Service Intervals: 12/10,000 - 'Variable servicing' option available.
Now that's what I wanted to hear!
nick
nick
Spax springs are very poor ride comfort from what I've read, so you might wanna upgrade those for a decent set ;). As for the Cat C stuff, make sure you get it fixed properly then certified.
nick
It's already been been VIC'd and given the all clear also had full 4 wheel alignment check and it came back fine so it's just a slightly twisted rear shell meaning that one rear door has almost zero panel gap but other than that it's fine. Just checked the specs and it's Koni sport springs and shocks, not spax. Not that I'm fussed as I run spax springs on my track car to great effect and I like stiff suspension anyway.
Nick
Nick
I just got mine done for £80 by a mate, basically it was £60 for parts and £20 for labour, so I shouldn't imagine the parts at least would cost much different.
I've been led to believe the 1.4 PD requires VAG-COM to be connected to time the water pump in (No idea why). If this was not the case I'd do it myself.
Nick
Nick
i'd say its more likely to check the diesel pump timing than the water pump.
Edited by pettsy
Nick
Yeah that would certaily make more snese.
Nick
Changing the timing belt and the water pump on the 1.4 tdi is expensive. Parts cost way more than £60 if i remember right the timing belt alone was £45 you then need to change rollers etc plus the pump. I had it done it a vag specialsit and they said it was a pig of job.
I bought a 2001 (51) plate silver, 3 dr 1.4TDI on saturday, it`s brilliant!!!
I`ve owned a Passat Estate 1.8T for the last 2.5yrs but need something cheaper to run, you can`t beat £35 road tax and 60+mpg. It`s totally standard apart from some quite nice aftermarket 15` wheels. It pulls really well for a little car, the more I drive it the more I like it, very comfortable too..
To give you some idea of how good it is on diesel, I put £20 in and drove 280 miles!!
I have a few mods in mind but keepin it subtle, nothing to rude. Buy one, now!
