wet footwels :( helpppp
hi guys
i recently purchased a dragon green 3dr 16v 6n, was cleaning it yesterday and found that both the footwells are soaked. :-(
i dont no how htis has happend, can any one HELP ME PLEASEEE.
can it b the heater matrix, someone said it cant as the water would have a sweet smell but the water was quite drty but is there any way to check the heater matrix is fine?
thanks pleasee help me :cry::cry:
  • Views 863
Might have same issue as me, check the door seals this is where mine leaks through :( ...
Also, get in the scuttle tray and take the pollen filter out. Clear out all the leaves from in there-they can block up the drainage holes, then water has nowhere else to go :lol:
Edited by Olly S
as olly said, this happened too me when we had snow earlier in the year, my scuttle panel was filled with leaves and then the snow just stock piled and melted :-(
in case your a total noob there is no reason to remove the pollen filter and the scuttle panel is the black plastic cover under the window wipers. remove the wiper arms and itll just pull out :-D
