Clear up some confusion please
This is my polo , now I had always been under the impression that this was a mk2 polo , log book says 89 so I thought yep it's a late mk2 breadvan.
However , recentley I have been having trouble buying parts for it like steering wheel hubs and other aftermarket parts, I had contacted "Technical Depts" from supplier to make sure before I bought stuff that the patrs would be correct for the car.
Only to find that they didn't fit , then sending them back to be exchanged for parts listed as suitable for the mk1 polo which do fit..
anybody clear this up once and for all .. is chubby the breadvan an mk1 or an mk2 ?
  • Views 871
Most people, including this forum, refer to your car as a MK2 Breadvan.
To stop any confusion, the best thing would be to say the year of your car as opposed to what MK it is?
whats probably happened with the hub for the steering wheel was that it was a late spec one.
vw changed the mk2 polo steering wheel spline in the late 80s to a larger spline (they just fitted an adaptor to the small spline, so early stuff will fit the later stuff with the large spline removed)
so at a guess I'm gonna say yours is an early mk2.
either way your car is 100% a mk2 and not a mk1!
The car does indeed have the small spline but it was registerd in 1989 so should have the later spec large spline ?????? I always give the year when ordering , is it possible this is an early spec car that has been registerd later for some reason ?
possible. think it was only the very last of the mk2s that got the large spline anyway. much of the mechanical parts are the same on the mk1,2 and 3 polos as they share pretty much the same chassis
