Off-side wing mirror replacement for idiots
Ok so I've managed to destroy my passenger side wing mirror by reversing past a brick wall at a strange angle - hey but you live and you learn ... quite slowly in my case. :oops:
Any tips on replacing it very welcome - is it easy to get spares? - is it easy to fit them? - should I just take it to a garage and pay lotsa money?
Thanks for any info!
- 1996 N-reg Polo by the way
Edited by sweet_science
  • Views 839
A bit of a dig, but:
It's really straightforward. Spares shouldn't be hard to find if it's a manual mirror. electrics can be a bit tricky to find. Manual mirrors shouldn't be more than 15,20 quid in good nick.
As for replacing it, well, if you have a haynes manual, follow that, otherwise, this:
Unscrew the door pin(lefty loosy, righty tighty)
remove the mirror inner trim piece(this bit, wedge a small screw driver from the top)
remove the door grab handle trim piece(the bit that goes on the end of this, the left on this picture, again, small screwdriver and you should be able to get at it from the bottom)
you will find two screws, unscrew them
remove the mirror knob plastic cover
next, use a large screwdriver and wedge it between the door and the door card. Wedge and maybe give it a small push/pull, to hear it pop. Do this all around the door card
once it's pretty loose, lift it up, over the door pin, grab the door lock handle and wiggle it out of the way
now you'll find three screws holding the mirror onto the car, and two screws holding the knob on. Undo these, and voila, mirror removed.
Refitting is the reverse of removal.
Offside is drivers side not passenger side ;)
