spliting the rear badge.
might be a noob question ...
but i want to split my rear badge in to two ... how do i do it ?
and once its split ... how do i get them back together ?
Chris
Edited by parfay_2009
  • Replies 8
HELP
all i wna know is does it just pull apart :)
I really wanna know if this is possible aswell guys, and also how to do the front badge?
BUMP
Does anyone know?
For a 6n right?
When I took mine off it was glue'd together so what I had to do was drill the glue out of the holes.
Then once I had resprayed the badge I used to super glue to stick em back together.
Eh? What is all this 'splitting the badge' malarkey?
you can split the rear badge into 2 parts ... so you have the VW part and the casing behind it seperate :)
Oh, I levered mine off with a screwdriver, it snapped the plastic mounting, but I glued it back together and it's been fine!
The front one is a piece of piss, just clips off! Take the grille off the car, and you will see.
