Mk3 Glovebox
Hi I'm doing up a 1992 Polo Genesis
I want a glovebox for it, mine is not luxery enough to have a door!
It seems to have all of the holes to fit one though
I was wondering, can one be salvaged from a Polo with a glovebox door
If so, Is this an easy Job, and where would I find a door/flap? Also, would doors/flaps from an 80s Mk2 fit? Or Just the Mk2f/Mk3?
Any wisdom much appretiated :-D
  • Views 830
the whole range is like a jigsaw
they fit straight on as long as you have the little pins that go through to hold it
not too sure about the mk2 but it might be worth checkin the breaking section on here as there's a few mk3s going atm
check mine i'm selling one buddy.
MKII ones dont fit, dash is pretty different. But if the set up is similar, you should be able to get hold of the whole glove box intact, save looking for just the door
