Will these fit?
Hi
I've seen some alloys i'd like to put on my 6n. The studs ar 4x100 and the alloys are ET38.
Will they fit my mk4 polo? I have standard suspension?
  • Replies 30
  • Views 3.7k
the should be fine, that is pretty much standard offset for VW alloys and the correct stud pattern.
If they are 7 inch wide or greater, it may foul the suspension legs/front calipers or rear axle, if so a set of spacers (hubcentric if you go over 10mm) should give you sufficient clearance
The tyres for them are 185/70 what spacer will i need for these?
you will need tyres like 195/45 15. they will be like balloons!
What do the tyre numbers mean?
I thought the first number ( eg. 185) was the width for the wheel?
They are 14" alloys
yeah 185 is the width of the wheel and the next number is the profile of the tyre. the higher that number, the bigger the sidewall of the tyre.
and the 14 at the end is the size of the wheel.
So is 185 trye size over 7"? if so what spacer will i need?
you dont need spacers for tyre sizes. spacers are put between the wheel itself and the hub it bolts onto.
185 is the width of the tyre itself.
so the tyre width has no relation to the alloy width?
Yes, but you have a certain amount of play in the numbers. 185 for example may fit, but using 165s (for example again) will give you a bit of stretch. If your looking for different tyre sizes and looks, check www.tyrestretch.com. It has a gallery of different sizes of tyres and wheels, with all different profiles too
The alloys are j6's so i wont need a spacer will i?
YOU DONT NEED SPACERS!
Will i be ok to put a lowerin kit on with these wheels. Also what tyres should i use?
Yes they will fit
No you do not need spacers
Yes you will be able to lower the car fine with those alloys
Tyres should be 185/55/14 so they are the same rolling radius as the originals
How big could i go? Could i go to 15's?
yes you can fit 15s on a 6n with ease.
no spacers needed.
it depends how low you want to go on what tyre you need without scrubbing. a 195/50/15 should be fine if you dont wanna be mega low.
Thanks for your help guys!!
What size tyres should i use on 15's?
depends how low you're going to what tyres you'll need without any scrubbing issues.
how low are you planning to be and how wide are the wheels?
Just 40mm front and rear?
Wheels are j6's
I think you should just leave your car alone. Sounds like your a disaster waiting to happen :lol:
But for arguments sakes.
195/50/15 broken down is
195 is the width of the tyre in millimetres (this is the bit where the tread is)
50 is the percentage of the width that is the tyre profile (the big where this is all written on)
15 is the tyre diameter measured from the inner part.
I'm starting to get my head round it now.lol
I found this web site...... Very useful.
http://www.etyres.co.uk/tyre-size-calculator.htm
It calculates the difference in rolling diameter between your old and new tyres.
no spacers needed.
195/50/15 would be wrong though. should be 45
