lock on driver door
hi everyone i was just wondering can anyone help me out i got an R reg polo n the drivers side door lock one day didnt lock now it just keeps on spinning around and the other day the barrel fell right out i dont want to change the key and locks cause that will take time is there any easy alterative thanks
  • Views 835
Happened to mine the day I bought the car!
What happens is the paddle and associated parts at the rear of the door lock break over time. Once they go the lock can spin and also you can pull the barrel out of the door.
You can buy a repair kit from Ebay for £15, or get a second hand door lock and salvage parts. You use the original barrel and keys, it's just the parts that attach to the barrel that break!
Edited by deviance
There's a part in the lock that's made intentionally weak, so that it bends if you try to force the lock. This'll be what's failed. As above, the repair kit is cheaply available, and not much more direct from VW.
