Possibly buying a new car
Hey guys, I'm brand spanking new to the forum but am very interested in getting a polo soon as possible really. Spotted this coupe s on ebay and looks pretty good to me but as i dont know what I'm looking for i thought id ask the experts opinion.
It says its got a rust patch on the drivers wing, is this a fairly common place rust appears on polos of this age and is it relativity easy to fix or will it need to go into a body shop?
I've been looking at these for a while now just for the reason that i love the styling and what some of the guys on here have done to them is amazing! Are they pretty good cars in general? Any major problem i should be watching for?
Any help would be really appreciated
Thanks, Aaron.
Link- http://cgi.ebay.co.uk/1990-VOLKSWAGEN-POLO...=item1c0d1ecf3d
Edited by azza46
  • Views 780
i dont really know too much about the older polos mate but i wouldnt worry about the rusted wing, you could easily pick up an old wing from a scrappy if it becomes an issue, and at worst it will need some TLC from a bodyshop. same for tailgate.
as with any car, i would be more interested in the engine and what service history it has.. ask about advisories on last MOT and any problems etc but from what the advert shows, car with an MOT for under £300 seems like a good deal.
would definatley be owrth checking out in person first though, as anything could be wrong with it.. dont want head gasket going on you as soon as u get it or nowt
Definately worth going to have a look :thumbsup:
The worst thing really is rust - if the wing is rusted, check the inner wing :)
Check everything, give it a good test drive - check the gearbox for whines/crunches
If you arent too sure then take a friend with you, and if its a first car then dont forget that you can always say no :thumbsup: There are plenty around :)
Yeah what's been said before really, the wing isn't such a big problem as you could pick one up from a scrappy or off here if needs be. Overall that looks like a nice tidy little car for 275 quid!
Have a look through the service history, ask when the cambelt was last done etc. Other areas to check are the battery tray (very common to rust through), the corners of the windscreen, under and around the arch trims mainly.
They're reliable engines as long as they're serviced properly and at the correct times. Sometimes the carbs are a bit of a b*tch on cold mornings, but other than that should be fine.
Thanks for the replies people, unfortunately, just as i went to insure it, direct line decided to charge me over 1000 pounds to be insured as a named driver on my mums policy! Couldn't believe it. Really gutted as i was really looking forward to getting it but oh well, may just have to get a 1 litre instead.
