Heater Backing Light Fault!
Alright then guys, Since i brought my 'Polo 6n2' it does this wierd thing.
When my lights are on, and i turn any of the heating dials the backing lights goes off, and then after you have waiting a while, they all come back on again and then turn a dial again and the same wierd thing happens again.
Anyone ever come across this? and if so did you fix the problem.
Cheers in advance guys
  • Views 794
It will probably be a loose bulb.
Turn the centre knob all the way to the left, then squeeze it and pull it out.
There will be a bulb behind there, have a fiddle with it and it should be fine.
cheers mate, is it the same technique to get them all out and check them?
Theres only one, which is filtered through to the rest
Ok mate il check it out when i get up tomorrow. Ill look out for you next time I'm in birmingham, my mate goes to uni up there, which campus you on?
Perry Barr matey
