Getting rear seats out 6n URGENT!
Just on my way to pick a full interior, including door cards, seats and pracel shelf so i thought i'd better take my rear seats out, to make room,
took the bases out easilly then when taking the back out i got stuck at the two pins in the middle of the 60/40 split, how do you remove these?
Thanks Jamie
Edited by Jamie_300
  • Views 1k
Thanks Jamie
i know i shouldn't but bump!
push them in towards one another.
it may be easier just to remove the two allen bolts instead?
i just done this,
Remove to Allan Bolts
Then get a flat head on the pin in the middle pri it open gently, then the clip it self should be able to push back then the seats should lift out, same goes for the other side, you need you get the lockthing looks like a claw just push it back on its self you will see what i mean when you attempt.
