Reattaching bump strips
So I took off the bump strips on my car and it seems the LH door has been painted, not due to the change in colour, but due to dip it left behind. Seems the bodyshop didn't remove the bumpstrip. Anyhow, now I need to put the bumpstrips back on as I think I'll sell the car soon. What can be used?
  • Views 1.2k
Try and find some decent glue that will stick it back on. Wouldn't be able to tell you what product to use but I would suggest you give it a decent clean before you stick it back on otherwise it might not stick too well :/
sticka flex sticks anything and thye will never get them back off lol
If you use SikaFlex you will never get them back off again without pulling the paint off, i.e if a repair needs to be undertaken or something.
I'll probably use some double sided sticky tape that some people use to glue on their number plates. Supposedly sticks like a mother f...
tiger seal ;)
foam double sided tape like they held on with from the factory? about £4 a roll
Don't stickaflex or tiger seal them on. Thats the work of a pikey. Use some 'trim tape'. Funnily enough its for replacing the tape that holds trim pieces on :lol:
